write as many snakemake files and with much faster iterations and completely from the single files or from the list of the files with the path appended. This will make your writing the snakemake easier
#!/usr/bin/env bash
# -*- coding: utf-8 -*-
# Universität Potsdam, Germany
# Author: Gaurav Sablok
# date: 2024-2-8
# a indexed based and brace expansion based way of writing
# the snakemake files for computing the below version is
# for if you have some files.
read -r -p "please provide the rule name:" rule
read -r -p "please provide the shell command:" command
read -r -p "please provide the input file directory:" inputdirectory
read -r -p "please provide the output file directory:" outputdirectory
declare -a snakeinput=()
while true; do
read -r -p "please provide me the input name:" inputname
if [[ "${inputname}" == "" ]]; then
break
fi
snakeinput+=("${inputdirectory}"\"${inputname}\"\,)
done
declare -a snakeoutput=()
while true; do
read -r -p "please provide me the output name:" outputname
if [[ "${outputname}" == "" ]]; then
break
fi
snakeoutput+=("${outputdirectory}"\"${outputname}\"\,)
done
for i in "${snakeinput[*]}"; do
echo "rule ${rule}:"
echo " ""input: ${i}"
echo " ""output:${snakeoutput[*]}"
echo " ""shell: ${command} ${snakeinput[*]} ${snakeoutput[*]}"
done
#!/usr/bin/env bash
# date: 2024-2-8
read -r -p "please provide the input text file:" inputtextfile
read -r -p "please provide the output text file:" outputtextfile
if [[ ! -f "${inputtextfile}" && ! -f "${outputtextfile}" ]]
then
while true; do
break
fi
done
while true; do
break
fi
done
done
fi
if [[ -f "${inputtextfile}" && -f "${outputtextfile}" ]]
then
declare -a inputtext=()
for i in $(cat "${inputtextfile}" | cut -f 1 -d " ")
do
inputtext+=("${inputdirectory}"\"${i}\"\,)
done
echo "the number of the files added to the input snakemake: {#inputtext[@]}"
echo "the files added to the input array are: ${inputtext[*]}"
declare -r outputtext=()
for i in $(cat "${outputtextfile}" | cut -f 1 -d " ")
do
outputtext+=("${outputdirectory}"\"${i}\"\,)
done
echo "the number of the files added to the output snakemake: {#outputtext[@]}"
echo "the files added to the input array are: ${outputtext[*]}"
echo " ""input: ${inputtext[*]}"
echo " ""output:${outputtext[*]}"
echo " ""shell: ${command} ${inputtext[*]} ${outputtext[*]}"
fi
