Docker compose YAML
If you are writing docker compose like me writing for some of the docker applications and forget a part of the YAML then here is a quick look that i keep for checking out the indentation as YAML is all about the indentation of the nested data.
# Rules to be remember for YAML
# Yaml (YAML Ain't Markup Language) is configuration management lanaguage for ansible and other CI and CD roles and integration.
# it is a data serialization lanaguage.
# Intendentation in Yaml is the same as Python which is very important.
# It supports one direction processing.
# Each code in YAML starts with ---.
# To correct the lint in yAML, clone this repo:  ![YAML Lint] (https://github.com/adrienverge/yamllint)
# YAML is case sensitive as python
# You can save the file extension as .yaml or .yml in ansible
# TABS are not allowed but spaces are permitted
# Provide comments as #
# Members are listed as -
# Listed members in [] and seprate by , such [ this is a reporsitory, please feel free to use it]
# Making an array, use {} and : such as {age: 41, method: scalar}
# : and , as list seprator
# ! and !! for URLs
# string are separated using ""
# commenting start with # as in many other lanuage and it can be a single line or in the multiple line commenting with #.
# You cannot # comment with in a block but you can write a block comment (see line 109-113)
# In YAMl, simply remember that
# Follow ![Cloubees] (https://www.cloudbees.com/blog/yaml-tutorial-everything-you-need-get-started)
# You can also learn a quick ansible YAML at: ![Ansible] (https://docs.ansible.com/ansible/latest/reference_appendices/YAMLSyntax.html)
# Start loading some examples in YAML as
    yaml.load ('2.4.4')
    2.4.4 same as python string definition
# To load a list like text, name, city, column in YAML
    yaml.load ('''
    -text
    -name
    -city
    -column
    ['text', 'name', 'city', 'column']
# Text defining
 # a) Block format
   - name
   - list
   - Title
# b) Inline format
   [name, list, title]
# c) Folded text
- {name: list, title: ansible} can also be defined as
- name: list
- title: ansible
# d) You can combine the inline format as well as the folded text in one
name: [list, text, place]
women:
     - list
     - text
     - place
### Check this block mapping in yaml (tutorialspoint.com, i added the line wise explanation)
--- !clarkevans.com/^invoice # URL starting with !
invoice: 34843
date   : 2001-01-23
bill-to: &id001
   given  : Chris
   family : Dumars
   address:
      lines: | # block with multiple lines but this will be read in multiple lines see the example below
            458 Walkman Dr.
            Suite #292
      city    : Royal Oak
      state   : MI
      postal  : 48046
ship-to: *id001
product: #### multiple block as this is important in ansible
    - sku         : BL394D
      quantity    : 4
      description : Basketball
      price       : 450.00
   - sku         : BL4438H
      quantity    : 1
      description : Super Hoop
      price       : 2392.00
tax  : 251.42
total: 4443.52
comments: > ## commenting with > is the same as | but it will be read as a string see the example below
    Late afternoon is best.
    Backup contact is Nancy
    Billsmer @ 338-4338.
# block reading with |
            458 Walkman Dr.
            Suite #292
# will read as
    458 Walkman Dr.
        Suite #292
# block reading with >
    comments: >
# will read as
    comments: ate afternoon is best.Backup contact is Nancy.Billsmer @ 338-4338.
### Commenting with a block
age: # this defines the age
   - 24
title: # this defines the title
   - list
### Defining a scalar and sequences, map the block with - and : , see the example below with the exaplantion
- name # These are seqeunces of scalars
- title # These are seqeunces of scalars
- list # These are seqeunces of scalars
age: 24 # Mapping of scalar to scalar
hr: 87 # Mapping of scalar to scalar
avg: 56 # Mapping of scalar to scalar
names: # Mapping of scalars to seqeunces:
  - title # these are sequences and listed with in a scalar with -
  - list # these are sequences and listed with in a scalar with -
  - origin # these are sequences and listed with in a scalar with -
  - playlist # these are sequences and listed with in a scalar with -
## Collection is a combination of the scalar and seqeunces and can have sequence to scalar mapping or the scalar to scalar mapping
## Important concept "Seqeunces start with -" & Scalar start with :
# Sequences
- name
- title
- list
# Scalar
time: 24
# Combination of sequences and scalar is called as collection
--- # start of the collection
name: Mark Joseph # Mapping of the sequence
avg: 0.278 # Mapping of scalar to scalar
... # end of the collection
# Defining complex structures: A complex structure can be defined with a dash, colon and question mark.
- 2022-10-23 # Defining a sequence
? [ name, list, title ] # Defining a complex structure
: [ 2022-10-23, 2022-10-22, 2022-10-21] # Defining a complex structure'
# scalar and tags in YAML:
# There are simple to remember scalar in YAML. | (pipe scalar) will convert the text into a single line (see line 94-100), whereas the > scalar will not wrap the line text (see line 101-107).
# Number and Miscellanous tags in the YAML
canonical: 12345 or 1.23015e+3
decimal: +12,345
sexagecimal: 3:25:45
octal: 014
hexadecimal: 0xC
exponential: 12.3015e+02
sexagecimal: 20:30.15
fixed: 1,230.15
negative infinity: -.inf
not a number: .NaN
null: ~
true: y
false: n
string: '12345'
become: true (in case of sudo, use become)
# complex YAML: Here look at the <<: *.defaults which is defined as the functional code means there is no need to write the same code again and the defaults from the first connection.
defaults: &defaults
   adapter:  postgres
   host:     localhost
development:
   database: myapp_development
   <<: *defaults
test:
   database: myapp_test
   <<: *defaults
# Understanding sequence, mapping and scalar with a functional code (tutorialspoint.com)
# the below example is an example of seqeunce, however with in the example, line 191:194 is a mapping
product:
   - sku         : BL394D
     quantity    : 4
     description : Football
     price       : 450.00
   - sku         : BL4438H
     quantity    : 1
     price       : 2392.00
# Indication charatcer one example and line wise explanation
--- # open the connection
!!map {
   ? !!str "sequence" # ? represents a mapping key
   : !!seq [ # : represents a mapping value ([ open square bracket open a flow sequence)
      !!str "one", !!str "two"
   ], # , represents a flow collection entry (] close bracket marks the end of the flow seqeunce)
   ? !!str "mapping"
   : !!map { # { marks the start of the flow mapping
      ? !!str "sky" : !!str "blue",
      ? !!str "sea" : !!str "green",
   } # } marks the end of the flow mapping
# This represents
# only comments.
!!map1 {
   ? !!str "anchored" # "" Style showing double quoted flow scalar
   : !local &A1 "value", # & represents the node anchor property
   ? !!str "alias"
   : *A1, # * denotes alias node
!!str "text" # ! repesents a nodes tag
In addition to above, % represents the directive, | is a literal block scalar and > is a folded block scalar
# Chomp in YAML: Chomp in YAMP is simple and is defined by strip, clip and keep. Chomp is not frequently used in DevOPS
strip: |- # Strip the text
   list
clip: | # Clip the text
   list
keep: |+ # keep the text
   list
# Defining string with special charatcters : In case of defining string with special characters, you should enclose them with " " so that the special character can be read
str: "learn yaml 3\n"
str: learn yaml 3
# Final touches to YAML: YAML is easy to code, simply understand the syntax:
--- # Start with the --- (3 hypen)
   student1: "anyone"  # (Make a key value pair)
   hobbies:   #( Define a key)
    - music  # (Make a list)
    - reading
    - dancing
  # OR Make many key value pairs or the list
   identity: "student"
   class: 3
   - reading
   - dancing
   subjectscores:
   - maths: 30
   - anything: ~ #(Defining a null value, either ~ or null)
To explicitly specify the type of data, use the !! symbol and the name of the data type before the value:
# parse this value as a string
date: !!str 2022-11-11
## parse this value as a float (it will be 1.0 instead of 1)
fave_number: !!float 1
YAML is more used to grant a user a special access. Like a favor for a client that is using your CPanel and doesn’t has some administrative privilieges based on his membership or hosting plans. But as a regular client you may provide him or her with a YAML file. Then he will setup and get some privilieges to not talk to customer support each time to interfere. I am talking about virtual machine or cpanel or plesk panel adopted with YAML. It happens sometimes.
