Hi I’m Rod. I’m a retired Computing and ICT teacher but did most of my work on Windows. I’ve dabbled in many areas and also run networks on Windows Server, Novell and … OS2! I looked into Linux years ago and thought I’d come back for more. I was doing an online Photography degree until I was kicked off for running out of time. I’m 73 and want to keep my brain running so I thought I’d ask Linux for some help
Welcome to the Community, Rod!
Any specific topic/issue requiring immediate attention?
Welcome to the community @rodcy, we’re glad you’re joining us ![]()
Hello everybody. I`m Elmu and i just love Linux, however im̀ total beginner and currently using Linux Mint.I hope learn a lot from anywhere i can.Thank You.
Welcome to the community @Elmu007, glad to have you here! ![]()
Welcome to the forums @rodcy @Elmu007 @Frentan @jebastin @StantheBear @PFreeze064 we are honored to have you join our community.
Hi Rod! Welcome to our forum community
Thanks for the welcome. I’ve been playing around with a few distros on a very old laptop. and ended up using MX. I’m trying to learn more of the command line and shell scripting. Just bought a used Thinkpad T480 and intend to install Ubuntu 26.04. Current plan is to set up as media server and also link to my Win 11 PC. I’m sure I’ll be calling for help
MX Is a solid choice! Welcome to our community. ![]()
That’s a good choice of systems: (Thinkpad T480) and distributions: (MX Linux).
There aren’t too many that are better than those two, especially if you are on a limited budget and want the most effective tools at a reasonable price. Morever, back in that generation, the T480 was among the easiest to fix and replace parts; some newer Thinkpad models lack that capability, but I recently read that Lenovo intends to respond to the feedback and start producing chassis designs similar to the T480 once again. I’d like that; the keyboard is also superior to the T14 Gen 3 that I’m using now.
As for MX Linux, you can’t ask for a much better distribution. You can install it and use it pretty much as is, but for the toolkit user and tinkerer, it’s also pretty good; you can morph your system into whatever you want pretty easily with MX Linux, so it’s the best of both worlds: very solid as is, yet flexible enough to modify to suit personal preferences or requirements.
Greetings and a warm welcome to you Elmu.
I would encourage you to look over the references and posts offered up in the following posting:
