After upgrading to a more powerful PC by building it from parts and keeping my two hard drives (Debian Linux and Windows 10), I’m having a few minor issues: the worst part is that I can’t get the Linux drive to mount, even though I can use its boot/GRUB loader just fine. It normally displays the mx/linux login screen, then the screen goes black and freezes indefinitely, with just a small blinking prompt in the top-left corner. However, when I selected the Windows drive, everything went smoothly and it works fine—the drivers updated automatically. I tried booting the Linux disk from an ISO file, but got the same result: a black screen and a blinking prompt.
Another, even stranger issue: my previous keyboard and mouse aren’t detected, whereas an old keyboard and mouse are… Annoying, especially since they only work halfway.
So, if anyone has any suggestions or ideas on how to fix these little issues, I’d appreciate it.
My specs:
Welcome @Syl The RTX 5060 is probably the issue. It’s a very new card running on an older kernel and drivers on your MX install.
You can test. Plug your monitor into the motherboard’s video out so it uses the Intel graphics, then boot. If that works, update MX (enable the AHS repo in MX Repo Manager for a newer kernel) and install a recent NVIDIA driver, and the keyboard/mouse issue may well clear up with the newer kernel too.
Tried with the intel graphics, but that just leads to the same black screen, albeit with no prompt at all. When ctrl/alt/F2ed with nvidia plugged, that blink to ‘Welcome to mx-linux! Powered by debain. login name:’ But i don’t have time to write anything, or simply cannot write anything.
So you tried to boot the Live ISO but can’t get that to run with a session.
Correct?
If so, the the issue is hardware recognition. The components you’ve used (at least one of them, a critical component) is not in the database of recognized components required for Linux to know how to recognize or set up the OS.
[2] Linux Installation
During the installation of the OS, were there no messages to flag that there was anything that was not compatible (not recognized)?
[3] BIOS Setting for Primary Disk
Was your OS, with boot/GRUB, installed on the physical Linux Drive? Or is that GRUB /boot/efi (or other) installed on the Windows drive? If the latter, that would definitely be problematic and you need to rebuild with
Linux drive being the primary device,
GRUB always defaulting to Linux, with Windows being a selectable alternate, and
Windows drive being pure Windows installation with no Linux-related content on that drive, anywhere.
Some people would say “Get rid of Windows 10”, and actually you SHOULD; Windows 10 is no longer supported as of October 14, 2025. Users are encouraged to upgrade to Windows 11 for continued support and security updates.
On the other matters, I believe that dialogue is underway; it’s a pleasure to have you join us here and I send a warm welcome to you!
Thxs, pleasure also to join this place with kind people. My main issue seems to be that i’m unable to download files in recovery mode. I managed to purge nvidia, but now i can’t install it: ‘unable to fetch’.
So, i managed to recover my files and format the disk(ntfs), but what’s really weird is that i’m still gettin the black screen with the usb iso… Can’t start the installation…
Maybe it’s because what “works” for one person doesn’t work for another person. Linux Mint and MX Linux are both popular distributions and they “do a lot” for you, but they are quite different. Linux Mint configures a LOT of stuff, including a few different user interfaces for you.
MX Linux hits a middle ground, providing a reliable way to use the system and a set of tools to allow the individual to configure the system the way they prefer it to be; both are “good approaches”, but they’re good approaches for two fairly different communities of users.
