I Built Gamma Linux to Give Old PCs Another Life 🇩🇿
Oh, I just found this:
Asus eeePC: AMD-C60 64-bit, 1GB-RAM:
I had to install some extra firmware for OpenGL, DRI and VAAPI (video decoding)
sudo apt install firmware-linux-free firmware-amd-graphics avinfo
Now plays high-bitrate H264 (AVC)/DTS full HD Video fluently :blush:
(without VAAPI it would absolutely be a slideshow)
I also discovered that Gamma Linux does not have a form of NTP installed, so here some instructions to make it work:
 # install the package
sudo apt update
sudo apt install systemd-timesyncd
# enable and start the service
sudo systemctl enable systemd-timesyncd
sudo systemctl start systemd-timesyncd
# enable NTP sync via timedatectl
sudo timedatectl set-ntp true
# check the sync status
timedatectl status
I pimped the desktop a bit:
thom@deimos:~$ free -h
               total        used        free      shared  buff/cache   available
Mem:           725Mi       253Mi       160Mi       852Ki       420Mi       471Mi
Swap:          7.7Gi          0B       7.7Gi
Gamma linux is a keeper :smiling_face_with_three_hearts:
Wow, this is awesome! :sob::fire:
Thank you so much for testing Gamma Linux on an EeePC with an AMD C-60 and only 1GB of RAM. This is exactly the kind of hardware Gamma is meant for.
The VAAPI/video acceleration findings are especially useful — and getting high-bitrate Full HD H.264/DTS playback running fluently on that machine is seriously impressive. :grinning_face_with_smiling_eyes:
Also, thank you for catching the missing NTP setup and documenting the fix. I’ll definitely look into making time synchronization work out of the box in a future build.
And I love that you pimped the desktop a bit :joy: — seeing people actually customize Gamma and keep using it is one of the best signs for the project.
I’d also love to feature your EeePC test on the Gamma Linux website, if you’re okay with that. :algeria::heart:
Thanks again for the detailed testing and feedback. This is exactly what helps Gamma get better.
Yes, no problem :slight_smile:
:grinning_face:Hello Thom !! ,
I updated The site as i said , you can view or leave
