FerrumPix: bringing photo management, RAW editing and image editing together on Linux
Thank you so much for your kind words! I really appreciate them.
Just one small thing I’d like to clarify: FerrumPix was never intended to be exclusively a professional photo editing tool.
You can just as easily use it as a simple image viewer, slideshow or photo gallery, without ever touching the more advanced editing features. They’re there if you need them, but they don’t have to be part of your workflow.
In fact, quite a few people are already using FerrumPix simply as a faster, more modern-looking alternative to applications like gThumb or XnView.
That’s actually an important part of my idea behind FerrumPix: keeping everyday photo browsing and management simple and accessible, while offering more advanced tools for those who want to go further.
And again, thank you for taking the time to follow the project.
I will clarify. I should have said “high-functionality”.
I did not mean to imply that the tool was intended for only professionals, just that I try to choose tools that offer a feature set closer to my needs, which are much less in scope.
As a senior, while I can give praise where it is due, I try to reign in my “jump ship” instinct and stay with what I am familiar with … unless abandoned by the developers of my preferred “App-providers”!
Hi Patrick,
I have been using the watermark tool in FerrumPix for a long time now - for the photos I post in this thread. I finally checked out the slide show feature. I thought I would just put this out there, because of your UI talent, and amazingly fast development times for complex programs. It’s just an idea to put slide show on steroids.
Photodex went out of business 10+ years ago, and the ip went to another company that seems to have let it whither. About twenty years ago I used slide shows for clients to review proofs - as well as a thumbnail to larger image sets. This is what introduced me to (at the time) a very old company called Photodex. They came up with various products aimed at different market segments. Proshow, Proshow Gold, and Proshow Producer. It gave me the ability to send a link that with a single click the client could review hundreds of photos. I made identical flash versions that the client could stop and advance one photo at a time. The client favorites were put to music, and had subtle motions. All very configurable. Flash is long gone due to security vulnerabilities, but video is still hot, and FerrumPix has a player, and it indexes seemingly media of many formats.
I put this together in about 5 minutes, but the UI of Proshow Producer are horribly small fonts. It is only because I know the program that I can do it so fast. This is a video of cats I’ve rescued (all my cats are rescues)
Rescued cats video on youtube
Patrick, I’ve been using a graphic logo all along - not text. If I don’t save the resized (web) image first - the logo sometimes gets pasted almost off screen or image editing area in the lower right corner. I assume this is because I have the scale setting ticked up a notch along with the largest fonts. I’ve been trying to grab it and pull it over the image, but sometimes get a scale handle instead.
The “Export to” is great. I did one tonight in the editor, and one in the export to module, and in the export modules. (good job). During the editor, export to, and export versions of watermarking - it doesn’t work unless the resize is done first, and applied to the image. In the Editor it refused to allow the logo to be moved to the lower left corner (screenshot). In the export to module I see you have placement co-ordinates. Maybe that is limiting the editor? Or maybe it is an order of operations thing in the exports?
Was getting my car worked on this morning, and decided to run a roll of film through my Kyocera Samuria X4 half frame SLR camera circa 1989. This was about the time Kyocera purchased Yashica, and all of Zeiss’s intellectual lens formula property. It has a great built in lens.
Watermark from the editor
Watermark via export to - a resized in the editor, and placed with the export to module. (no opacity available) Many tries to resize and place a logo from full resolution image failed the watermark part.
Noticed:
screenshot of logo stopping halfway in move from right corner to left corner
Also, the settings for “Match camera Brightness and Colors” that seemed to help with my 5D mark III raw files - did the opposite with black and white film negatives digitized with a 5DS-R. Once turned off - the convert to positive and the black and white tick boxes were almost perfect.
Jim, i think this may be a positioning issue rather than an export-order issue. Image watermarks use an anchor: for the lower-left corner, select the lower-left dot in the Anchor grid in the properties panel, then use Offset X and Offset Y for the margin from that corner.
If the anchor is still set to lower-right, dragging is deliberately limited and it can feel as though the logo cannot reach the opposite corner. UI scaling does not change the exported position, but with large fonts the Anchor and Offset controls may simply require scrolling further down the panel. On a small image, the fixed pixel size of the logo also occupies a much larger share of the canvas.
Could you check which anchor and X/Y offsets are selected in the screenshot?
Patrick, It likely is me, but here is what I’m doing with “Export To” from an edited b&w film negative that is full resolution. BTW, Fog feature is VERY cool!
The anchor point selected was the lower right corner. I use drag-n-drop to position the logo so I don’t know the coordinates.
Watermark with EXPORT TO
What emerges is a 1500 pixel (on the longest axis) not watermarked image in the correct folder. I tried leaving the watermark size at default (usually 19x17px), and what it’s actual size (75x70px) - neither worked. I also don’t see an opacity setting or flatten command.
Watermark with EDITOR
(Not shown is resize, save as, changing the logo width, and flattening)
Odd Behavior
I ran into a potential bug while checking out the Lighting. B&W negative > Flip horizontally, rotate, convert to positive, tick the B&W box, and when I touched the Highlight slider the image washed out to a pale version. Next I tried not using the Highlight slide and got a little further, but it washed out again. Next tried just the Convert to Positive, but no B&W tick box, and was able to finish the edit.
NOTICED:
The anchor graphic outline is hard to see, for me
Here is the finished watermarked image
Hi Jim,
Thanks for the screenshots!
Watermarks when using “Export to”
The new version going out today (0.9.76) should fix the problem you ran into.
The issue was that when you resized an image during export, the watermark was scaled down along with it. So if you exported a photo at 1500 pixels wide, your logo could end up being just a few pixels across, making it almost invisible.
I’ve fixed that now. Whenever you enable resizing during export, you’ll also see an option to keep the watermark at its original size. That way, your logo stays the size you intended, regardless of the exported image dimensions.
Watermarks also keep their full appearance now, including blend modes, outlines and shadows, just as you saved them.
Opacity and margins
I’ve added two more options to the export dialog: a slider for the watermark’s opacity and a setting for its distance from the corner.
You can adjust both for each export without changing your saved watermark. There’s no need to flatten anything beforehand, either. FerrumPix simply adds the watermark directly to the exported image.
Black-and-white negatives looking washed out
You were absolutely right about this one. It turned out to be a bug, so thanks for pointing it out!
When you enabled negative conversion, FerrumPix was still using some of the camera’s default RAW settings. With your 5DS-R files, that included the exposure adjustment stored by the camera, for example when Highlight Tone Priority is used, as well as its colour calibration.
Those settings make sense for normal photos, but not for scanned film negatives. The extra exposure made the converted image look washed out, while the camera’s colour calibration pushed the black-and-white tones towards grey.
That also explains why “Match camera brightness and colors” seemed to do the exact opposite of what you’d expect, even though it works well with your regular 5D Mark III photos.
I’ve changed this now. As soon as you enable negative conversion, FerrumPix uses neutral values instead of the camera’s defaults. Any adjustments you’ve made yourself are left untouched.
That should give you a much better starting point for your scans. If the image still gets washed out when you adjust the Highlights slider, though, please let me know. I’d like to have another look if that’s still happening.
Anchor points
I’ve also made the anchor points easier to see by giving them more contrast. This applies to watermarks, objects, the canvas and collages, so hopefully they’ll be easier to spot now, even against busy backgrounds.
Best regards, Patrick
Patrick, Thank you again for being so responsive. Here is what happens in 0.9.76-1 VM Mint MATE
Flip horizontally > tick “convert negative to positive” > tick “black and white negative” > was on my way to adjust brightness, when it washed out all by itself?
So I switched the order
Flip horizontally > tick “black and white negative” > then ticked “convert negative to positive” > did all the adjustments and a save as. No problems?
In the new Export To module (love it) I ticked the “don’t scale watermark with image” I left the default watermark size > did the export. Got the right sized image, but a tiny tiny logo. Went back and entered the logo’s actual size and coordinates, and got the correct sized logo.
Thank you for the fix to the Anchor diagram. The ground was covered in polished pine needles. It just doesn’t look as good as it was in person.
Patrick, so many updates, and only so much time in a day to find them - even with your thorough descriptions for each update. I spent half the day getting Proshow Producer to run in UbuntuMATE 24.04.1, success - sorry about that tangent a few posts ago.
I have a thing about fog. I love the stuff, but for me to drive in it would be foolish with my vision. With FerrumPix I can re-imagine landscapes with a layers kind of view or the mind’s eye. So here is that result from a August 10th outing using the Canon 5D mark III and the 1960 Nikkor-S 5.8cm f1.4 Nippon Kogaku – (non-AI) lens
Imaged and “Export To” - Sized the Watermarked > set Opacity > Coordinates of Logo > Resized the image > set the Export destination, and added a suffix to the name. Wow! Great module. I just need to add some adjustment presets for future exports.
No Fog
Re-imagined with fog, and used “Frame” color picked the bottom of the dock.
I’ve Noticed so many UI touches, but I love the open/closed eye icons for a setting on/off on so many adjustments is a wonderful addition.
Moin Jim, thank you so much for the kind words and for sharing your photos! It’s really nice to see what you’re creating with FerrumPix. :slight_smile:
And sorry about the constant stream of updates! I know it must be difficult to keep up sometimes, even with the release notes. Version 1.0 is getting very close now, though, and you may have noticed that the updates are already starting to slow down a little. :wink:
By the way, if you like the eye icons for enabling and disabling adjustment groups, there’s another little feature you might enjoy: try right-clicking on an individual slider, or on the RGB, R, G, B or L labels in the tone curve. This lets you temporarily disable and re-enable individual adjustments without losing their settings. It’s quite handy for comparing the effect of a single adjustment.
Thanks again for all your feedback and encouragement!
Hi everyone,
Another substantial update is here! FerrumPix 0.9.77 brings quite a few improvements to everyday photo management, metadata handling, importing, searching and the viewer. There are also several fixes for RAW+JPEG workflows, PSD compatibility and exporting.
A new welcome and setup experience
On the first start, FerrumPix now guides you through a short setup:
  • Choose your language.
  • Select the appearance of the application.
  • Choose which AI models you want to download.
  • Select your graphics card, if you have one.
Everything takes effect immediately, and you can change these choices later in Settings. You can also run the setup again whenever you want.
Existing installations will see this setup once after updating.
Much better metadata management
This is one of the bigger additions in this release.
There is now a new Title and Description dialog in the Metadata menu. It lets you edit the following fields for one picture or an entire selection:
  • Title
  • Headline
  • Description
  • Creator
  • Credit line
JPEG, PNG and WebP store this information directly in the image file. JPEG also gets the corresponding IPTC fields. Other formats, including RAW, use XMP sidecars.
These fields are also searchable in the gallery, can be used as conditions in saved searches, and can be displayed in the information sidebar (disabled by default).
When exporting a developed RAW file, its title and description are now carried over from the sidecar into the exported image.
There is also a new File and Catalog comparison dialog. It displays the metadata stored in the image file and in the FerrumPix catalog side by side. You can copy or remove individual values in either direction.
You can also synchronise ratings, colour labels, pick/reject marks and keywords between files, sidecars and the catalog.
The metadata removal dialog has been improved as well. Instead of simply removing everything, you can now choose exactly what to remove – for example keywords, title and description, copyright or location – and where to remove it: from the file, sidecar or catalog.
More powerful gallery search
The gallery search and saved searches now support more metadata fields.
You can search for:
  • Place names and copyright notices.
  • Copyright as a condition in saved searches.
  • Keep and reject marks.
  • Colour labels and ratings.
  • Fields that are empty or not empty.
The rating selector now displays stars, and colour labels use the same visual representation as in the information sidebar.
The search dialog has also been made wider.
Import improvements
Importing from memory cards is a little easier now.
The list of shooting days has buttons to select all days, none, or just the most recent day. This should save quite a bit of time when working with cards that contain many days of photos.
Adding keywords in the information sidebar is quicker too: press Enter to add a keyword, and the field is immediately cleared and ready for the next one.
Gallery, viewer and filmstrip
A few improvements make everyday browsing more convenient:
  • Kept pictures now show a green thumbs-up symbol on their gallery thumbnails, just like rejected pictures already have their own mark.
  • Clicking the thumbs-up removes the keep mark.
  • Both indicators can be disabled in the gallery settings.
  • Rating stars, hearts and metadata symbols now have stronger shadows to remain readable on bright images.
  • The gallery’s left sidebar with sources and folder tree can now be collapsed, giving you more room for the pictures.
  • Both gallery sidebars can be resized, and their widths are remembered.
The information sidebar has also been moved to the far right in the editor, next to the layers panel.
In fullscreen mode, you can now show or hide it using a new button in the control bar or the I key. The image makes room for the sidebar instead of simply being covered by it.
There are settings to keep both the information sidebar and filmstrip visible in fullscreen mode. The control bar also remembers your choices.
The rating bar at the top of fullscreen mode and the slideshow can now be switched off in the viewer settings.
The filmstrip gets two new optional settings:
  • Show the edited mark from the gallery thumbnails.
  • Keep the selected picture centred, so the filmstrip moves instead of the selection.
Focus peaking in the viewer
A new feature for checking focus without constantly zooming in:
Focus peaking highlights sharp edges in red , making it easier to see which areas of an image are in focus.
Press K to toggle it. The setting stays enabled when moving to the next pictures.
More improvements to image editing
The colour mixer now has an eyedropper. Click a colour directly in the image, and the mixer automatically selects the corresponding colour range. This also works with black and white images, where the selection is based on the original colour beneath the grey tones.
Gradient masks have also received an improvement: the brush now works in Intersect mode with both linear and radial gradients. It keeps only the part of the gradient you paint over, and you can subsequently add more areas or remove them again.
The text tool now has an All Caps button next to Bold and Italic. It displays the text in capital letters without changing what you actually typed. This formatting is also preserved when importing and exporting PSD files.
Export and watermark improvements
The watermark settings in the export dialog are now more flexible.
You can adjust the margin from the image corner and the opacity for each export individually, without changing the saved watermark itself.
The exported watermark also retains its blend mode, outline and shadow.
There is a fix for the watermark size as well: when resizing an image, the option to preserve the watermark size is now available whenever resizing is enabled. This prevents the watermark from unexpectedly shrinking to just a few pixels on smaller exports.
Similar pictures and Windows ARM
Similar pictures are now grouped more strictly. Every picture in a group must resemble all the others in that group. Two different pictures will no longer end up together simply because both resemble a third picture.
The portable Windows ARM package now supports video playback and opening HEIC and JPEG XL files, just like the x64 package.
Lens correction also knows two additional Nikon lenses, including the Nikkor Z 24-70mm f/2.8 S II.
Fixes and other improvements
There are quite a few additional fixes:
  • RAW files open faster in the editor and are no longer developed twice in certain situations.
  • Film-negative conversion no longer briefly turns converted images pale after activation.
  • RAW+JPEG pairs now behave consistently when setting keep/reject marks, ratings, hearts and colour labels in the viewer.
  • The “Kept only” filter includes the entire RAW+JPEG pair, even if only one file was previously marked.
  • PSD text using OpenType fonts with CFF outlines retains its font when opened in Photoshop.
  • PSD selections, layer masks and vector masks are preserved more reliably.
  • Mixed formatting in PSD text layers retains fonts, sizes and positions more accurately.
  • Settings now open immediately, with the remaining sections loading in the background.
  • Display profiles are now available for monitors whose Windows drivers do not report a display name.
  • Printing from the Flatpak now opens the PDF viewer correctly.
  • Several camera models now have better-matched initial RAW brightness, including the Canon EOS 350D and EOS R5 Mark II, Fujifilm X-H2, Nikon Z5 II and Sony A7 V.
Your feedback is always welcome!
Wow! There is so much detail in here; the graphic expertise here is vastly beyond anything I can fathom, but it’s great to review and look at!
My comprehension of the details in your posts is limited, but the art work here is certainly first rate and I can without a doubt appreciate it and I do very much!
Thanks for all that you’re contributing!
Thanks, Brian! I really appreciate your kind words! :slight_smile:
And I have to say, the incredibly detailed feedback I’m getting from Jim has been enormously helpful. He puts a lot of time and effort into testing things, finding issues and suggesting improvements, and that really helps me make FerrumPix better.
Quite unexpectedly, I also came across this comparison today, where Marc takes a closer look at the actual image quality of four RAW editors:
Maybe that’s interesting for anyone who enjoys digging a little deeper into the technical side of image processing.
But there’s one thing I’d really like to emphasize: FerrumPix isn’t meant to be a tool just for photography experts or people who develop RAW files.
You can just as well use it as your everyday photo viewer, browse your pictures, organize your collection and completely ignore all the advanced editing features if you don’t need them.
That’s actually an important part of what I want FerrumPix to be: a photo application that can do a lot, but doesn’t require you to know or use all of it.
You certainly don’t have to be a professional photographer to enjoy using it. :slight_smile:
Thanks again for your encouragement, Brian. It really means a lot!
This is what I use it for.
Felt like some infrared yesterday, so I went to the beach where I could see from 20 miles away the sun was coming out. Started imaging to David Gilmour again, but switched to Bob Dylan (new playlist) - and yet another new FerrumPix was awaiting. v0.9.78-1. I think my MX & MintMATE VMs don’t like Pipewire, or some latency setting, because it is messing (stuttering) with my audio and video?
I also made a variety of watermark sizes as I noticed the Export To module seemed stuck on a default 75 pixel logo being 19 px - which I had to manually correct each time. Thought it might remember other sizes if there were a few more saved templates, and it did. Will make some 75 pixel versions to over-write the existing ones.
I noticed the change in color temperature right away in FerrumPix to degrees kelvin on raw files in the Color Adjustment (maybe I missed it earlier). The camera used (Canon 5D mark II) is one I used in my studio years ago, but sent off a few years back to get a 665nm infrared conversion. Lens is an old rectilinear 17mm f3.5 Tokina with a Nikon F-mount that I adapter to Canon’s EF mount. I employed many tweaks to this image. Distortion, straighten, individually color adjustments (if I can get a gold sky that is what I want), healed a couple sensor spots (dust), noise reduction, exposure, highlights, shadow, white and black point, clarity, multiple layering sessions to increase dynamic range on the sun paired with an eraser, I even used the burn and dodge tools - which I haven’t tried since Photoshop v2 in 1989. (they were crude tools then :grinning_face:) Most of my IR shots I prefer in black and white - so finishing the color version was going to take too many steps to approximate a history brush. Here is what I got
Two more quicker versions using the save/paste settings, tried out canvas sizing, more layering and tweaks. Being able to apply previous settings saves a ton of time.
Noticed:
-Export To does truncate file names that have a period in their name - right at the period. I constantly use periods - f1.4, 2.8 etc
Suggestions (unless, of course, they already are there)
-Drop shadow in layers or even canvas
-Three colour capital letters for switching between Viewer, Gallery, and Editor (E-G-V). Maybe it’s early dementia :grinning_face_with_smiling_eyes:, but have trouble switching.
-more cow bell on the Eraser brush size - 5000px instead of 2000px
A drop shadow would have dressed this up a bit
