Apptainer-devops
Hi all,
If you are using apptainer then here is a golang application i coded and you can find it here GitHub - codecreatede/golang-apptainer-devops: a apptainer golang devops
it does all the work for the apptainer and i am also adding the support for the conversion to docker and direct http JWT authentication token if you are from outside server.
Thank you,
